Auteur Sujet: 1965 404 Sedan from Russia  (Lu 9032 fois)
Lexx
Re : 1965 404 Sedan from Russia
« Réponse #30 le: avril 09, 2014, 15:23:36 »
Meanwhile in Russia...
The crankshaft and con rods returned from workshop. Everything looks good, the dimentions are OK, I hope it will run well.
The rear thrust bearing appeared to be worn for about a millimeter, so I needed some replacement. I couldn't find the original ones anywhere, but fortunately the bearings from russian car VAZ-2101, also known as FIAT-124 are exactly the same! The price is 1 Euro for a pair:
The left one is new bearing from VAZ, the right one is hevily worn original from my engine.
I also received the liners and pistons set for 504 model.
The only difference I see is 23 mm wrist pin. So I will take them to the work shop to replace the rod bushings. I've got three original 23mm ones and the last one will be manufactured here.
These are the news :)
« Modifié: avril 09, 2014, 15:25:16 par Lexx »
« Réponse #31 le: avril 10, 2014, 05:42:58 »
Good work!
Hors ligne vd71272
  • Membre du club depuis 1999
« Réponse #32 le: avril 10, 2014, 15:02:08 »
Great!  :)
